Question Need help choosing a specific optical mouse
brecmadak
8
I'm looking for a replacement for my DeathAdder. Solid build quality with a good sensor and responsive buttons. I need at the least 3 programmable buttons. Rubber gripping would be a plus.
  • Games: RPGs
  • Hand Preference: Right / Ambidextrous
  • Budget: ~€50
  • Hand Size: 19 x 11cm
  • Grip: Claw
  • Weight: Adjustable (preferably)
  • Sensitivity: Low DPI - smooth acceleration & precise tracking
  • Connectivity: Wired
Thanks for your attention and help!
Qyndryx
13
If you liked the Deathadder, check out the Logitech G403. It's very similar in style but it is a considerably better mouse.
