I am currently choosing parts for my gaming build. I plan to use this build to play the latest games and plan to upgrade it in the future. I will be starting with just one GPU and 16 GB RAM (2x8 GB). I would like to add additional GPUs and either add more RAM or get better RAM later on. Future VR and 4K capability are both pluses. This is my first time building a PC and I am torn between several different motherboards and would really appreciate some help with choosing one. Sorry if I have a lot of questions or if they seem like stupid questions. I'm just very new to this and want to ensure that I can build a working gaming rig ASAP.
Here are the motherboards I am torn between:
MSI MSI Gaming Z170A GAMING M5 LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 ATX Intel Motherboard
MSI MSI Gaming Z170A GAMING M7 LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 ATX Intel Motherboard
I have read on this site's forums that MSI has poor QC. Is this true? If so, I assume that I should avoid buying MSI motherboards.
GIGABYTE G1 Gaming GA-Z170X-Gaming 7 (rev. 1.0) LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboard
ASUS Z170-A LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboard
ASUS SABERTOOTH Z170 MARK 1 LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboard
ASUS SABERTOOTH Z170 S LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboard]
ASUS ROG MAXIMUS VIII RANGER LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboard
ASUS ROG MAXIMUS VIII HERO LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Gaming Motherboard
I've noticed that this board has received very mixed reviews on Newegg. I have also noticed that it's been recommended a few times on this site's forums, and it seems to have done well in the reviews I have found on some other websites. Which sources should I trust? If it comes down to this board vs. the Ranger VIII would prefer this one to the Ranger VIII, but I am concerned about buying it due to some of the negative reviews it has received on Newegg.
I am open to suggestions of other boards. I only listed ASUS, MSI, and Gigabyte boards because they are the manufacturers people have recommended to me the most. Are any of the other manufacturers' boards worth it?
Also, I know that some of these boards support memory speeds above 2133MHz if overclocked. Should I stick with 2133MHz for now, or should I get memory with a higher speed?
Here is a link to a list of the components I currently plan to use in my build, if you need to refer to it: http://pcpartpicker.com/user/Sharknat0/saved/tTswrH
Thanks! And again, sorry if I'm asking a lot of questions.
