I need help deciding which one to get. I don't see a big difference, but I would like someone to see if there's something I am missing. From what I can read, there seems to be more "cooling" options on the Aorus? Is it worth to spend an extra $10 on the "Aorus M" over the "DS3H"? I am using this for gaming mostly. here is a list of my current build (the motherboard is undecided of course) https://pcpartpicker.com/user/jonpdeleon/saved/#view=tGzCbv
Here are the motherboards:
https://www.microcenter.com/product/510208/b450m-ds3h-am4-matx-amd-motherboard
https://www.microcenter.com/product/510207/b450-aorus-m-am4-matx-amd-motherboard
One more thing: Under the specs and memory type for these boards, they have specific "memory types" for the dd4. My ram is DDR4 2666mhz, and it is not listed on what the memory type for the boards are. Are all DDR4 mhz types compatible with these boards? Excuse my ignorance. Thank you!
