Question Need help choosing between 2 builds
Mar 29, 2019
Ok so I got 2 builds that I wanna buy. I'm pretty sure I'll take one of them so don't build me a new one.I plan on playing mainly fortnite and potentially heavier games down the line on a 144 Hertz monitor (important to get to 144 fps more than higher settings). Just wanna see which one you think is better.
People in forums in my language say that the first build is better, and I don't really see why. Benchmarks tell otherwise. Anyway here are the builds.
(Don't mind the necessary parts in a build that are missing).
First build:
Ryzen 5 2600 box
Sapphire Rx570 4GB Pulse
Gigabyte b450M S2H
Corsair vengeance 2x8 GB ram
Antec neo eco 550w 80+
Second build:
Ryzen 5 1600 box
Gigabyte GA A320M S2H v2
Gigabyte Gtx 1060 6GB aorus
Same ram
Antec vp 500PC
Edit: also the first build is about 50 dollars cheaper from the second one but not really relevant for me
build:
Ryzen 5 2600 box
Gigabyte GTX 1060 6GB aorus
Gigabyte b450M S2H
I told you I'm getting either one of the two I posted... It's Out of my budget man you think I wouldn't go for it if I could?
Would like if you could answer my question guys :)
