Hi guys,
I have a real dilemma right now,
for my future build for a while I've been planning on getting the asus maximus hero vi, but silly me overlooked the fact it doesn't have built in wifi (which is a necessity for me). After only a little bit of research I found out I have these options:
Asus Maximus Hero vi (without rog armor and wifi)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131989
Asus Maximus Hero vi (with ROG armor and built in wifi but is 90 dollars more)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132038
or
Asus Z87 Pro (with wifi and about the same price as the original Maximus Hero vi board)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131979
Also keep in mind if I go with the original Maximus Hero vi board would have to get a wifi adapter (which is hard to find a really good reliable one that doesn't start go bad with in a couple of months). Or should I go with the z87 pro which isn't exactly a board made for exactly gaming.
I know there other options as well and if you know some please link them (preferably made by asus and is LGA 1150 socket compatible). But out of three which should I choose?
I will be gaming mostly on this computer btw, if that helps
or
that's why we are here
