Someone said the B2 monitor has about 25ms of input lag. There is the GB2488HSU-B3
https://iiyama.com/gb_en/products/g-master-gb2488hsu-b3/
which costs more than the AOC but if you're just gaming the AOC works fine:
https://www.youtube.com/watch?v=rTPxUt5OhlU
Looks like it has decent viewing angles
https://www.youtube.com/watch?v=ECmq17BtgUc
https://www.youtube.com/watch?v=_LmjB6TbIiA
If you decide on the AOC:
NOTE When tuning your monitor's brightness and contrast, do it from the picture boost menu in the monitor's built in settings. make sure bright frame is turned on and the frame size is set to 100%. your picture will be really dim and grey otherwise.
Make sure to set your monitor's refresh rate to 144hz in the windows display adapter properties menu, by default 75hz. google "ufo test" to see the settings are applied.
If you need them there are color calibrations from
http://www.pcmonitors.com
This needs no extra drivers for Windows 10 using DVI. For DisplayPort download drivers from AOC
http://aoc-europe.com/nl/products/g2460pf#support-download
To install
https://www.youtube.com/watch?v=9GrYpQeTNks&t=1s
Make sure that in windows the option to install unsigned drivers is possible, if you do not know how
https://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/
Restart PC. Pull out the DisPlayPort Cable on the graphic card then put it back after 1 minute.
