My build -
AMD RYZEN 2600 Processor
Gigabyte B450 Aorus pro WiFi Motherboard
Corsair vengance DDR4 8gb×2 RBG
240gb ssd
Cooler master ml240 rgb Liquid cooler
Hard Disk 2tb seagate
Gigabyte GTX 1080 VR ready graphic card winforce triple fan
Corsair 650watts smps
APC 1100va ups
Mechanical keyboard
Predator z35 200hz monitor
My question is which cabinet should I use for this. Because I have import tax and the price of case are twice. And I'm little short on money. Ppl suggested me to choose the case properly BC of the triple fan GPU and the need of proper ventilation. Can I use any of these cabinet mentioned below. And I will be adding 3 RGB thermal take fans to it.
1) thermaltake view 28
2)deepcool mattrex
3) Nzxt s340
My friends suggested me to go with higher end case because the once I mentioned above won't have proper ventilation if I overclock my GPU and CPU. Is it so? Or should I consider buying a higher end case like
Cooler master h500
Corsair crystal 570
I prefer a transparent view of my components. And I live in India so not all the cases are available here. So can I stick with my list of cabinets or should I consider buying the once my friends have said? If so why. Thanks in advance.
240gb ssd
APC 1100va ups
Mechanical keyboard
2)deepcool mattrex
3) Nzxt s340
Cooler master h500
Corsair crystal 570
