Need help choosing components for new Pc.
AzaPattaz
38
Hi there. I think its time for a new computer, however, I'm still a big noob at choosing the right components. Could anyone help me out here? My budget is about £1000/ $1445
I would like something like a 970 or 980 and possibly like an i5 6600 but I don't know if they would be compatible together. 8gb of ddr4 ram, 2 TB of storage and this awesome case:
https://www.amazon.co.uk/NZXT-CA-S340W-B1-Source-Midi-Tower-Case/dp/B00NZHV8AQ/ref=sr_1_1?ie=UTF8&qid=1461777635&sr=8-1&keywords=nzxt+case+s340
Could you also include a copy of windows 10 in the final build please. Thanks
Thanks, guys.
PCPartPicker part list: http://it.pcpartpicker.com/p/zTWdjX
Price breakdown by merchant: http://it.pcpartpicker.com/p/zTWdjX/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor (€203.63 @ Amazon Italia)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler
Motherboard: Asus H170M-PLUS Micro ATX LGA1151 Motherboard (€101.94 @ Amazon Italia)
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2400 Memory (€35.35 @ Amazon Italia)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive (€87.60 @ Amazon Italia)
Storage: Hitachi Ultrastar 7K3000 2TB 3.5" 7200RPM Internal Hard Drive (€79.00 @ Amazon Italia)
Case: NZXT S340 (Black) ATX Mid Tower Case (€79.98 @ Amazon Italia)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply (€79.50 @ Amazon Italia)
Operating System: Microsoft Windows 10 Home OEM (64-bit) (€99.77 @ Amazon Italia)
Total: €766.77
Generated by PCPartPicker 2016-04-27 19:37 CEST+0200
PCPartPicker part list: http://it.pcpartpicker.com/p/Y3CcZL
Price breakdown by merchant: http://it.pcpartpicker.com/p/Y3CcZL/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor (€242.80 @ Amazon Italia)
Motherboard: Asus Z170I PRO GAMING Mini ITX LGA1151 Motherboard (€151.92 @ Amazon Italia)
Total: €855.92
Generated by PCPartPicker 2016-04-27 19:38 CEST+0200
the first build list is with a locked i5 and a locked mb. the second build is a k cpu and a z170mb. there no gpu as both amd and nvidia in june are dropping newer gpu.
http://www.pcadvisor.co.uk/feature/pc-upgrades/nvidia-pascal-uk-release-date-price-specs-rumours-1080-3634003/
http://arstechnica.com/gadgets/2016/04/amd-polaris-will-be-a-mainstream-gpu/
http://wccftech.com/amd-polaris-10-desktop-polaris-11-notebook-gpu/
logainofhades
Smorizio, that is the wrong currency.
OP, you actually have the budget, to squeeze in an i7. If you intend to keep this system, for awhile, it might be a good idea to go with one.
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor (£248.94 @ More Computers)
Motherboard: ASRock H170 Pro4S ATX LGA1151 Motherboard (£82.15 @ More Computers)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2133 Memory (£32.45 @ Ebuyer)
Storage: Sandisk Ultra II 240GB 2.5" Solid State Drive (£64.99 @ Amazon UK)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive (£52.97 @ CCL Computers)
Video Card: XFX Radeon R9 390X 8GB Double Dissipation Video Card (£319.98 @ Ebuyer)
Case: NZXT S340 (Black) ATX Mid Tower Case (£54.71 @ CCL Computers)
Power Supply: XFX 650W 80+ Bronze Certified Semi-Modular ATX Power Supply (£73.95 @ Amazon UK)
Operating System: Microsoft Windows 10 Home OEM (64-bit) (£73.98 @ Ebuyer)
Total: £1004.12
Generated by PCPartPicker 2016-04-27 19:02 BST+0100
AzaPattaz
38
This is the most nooby question ever but how would u install windows? I thought u could only get the legit version via disk meaning I wouldn't be able to install it. I know you can do it via USB but I didn't know that you could get legit codes for it
Ari3l
114
22
You can get the ISO from Microsoft and use RUFUS or some othe rtool to put it on a usb and it's completely legal. whether you want to buy a key or use a "very famous ez to use program" to activate is your choice.
pssssst: Do what you want cause a pirate is free.
btw, if you go the usb way you throw in other things instead of buying that dvd drive/windows install.
Ari3l
114
22
So he should go with a mobo with less future proof features cuz his current CPU is not made for overclocking?
Z170 is the base for a nice gaming rig, you can even still get the sky OC firmware to overclock non k processors and z170 can use faster ram which will make gaming better in cpu bound scenarios (i3 and i5) according to Digital Foundry's benchmarks.
If you have the budget, don't go for less. if you want the 6600k just remove that dvd drive and windows disc...
logainofhades
Overclocking isn't necessary, and CPU is rarely upgraded. By the time an i5 6500, or i7 6700, really needed upgraded, it would be time for a new platform anyway. Intel's small performance bumps, each generation, doesn't help either. Even an i5 2400 is still viable for gaming, paired with a decent GPU.
For the windows install, you can buy the Windows disc, use Microsoft's media creation tool to make a bootable USB drive, with your version of Win 10 on it, that can be used for installation. When it asks for product key, use the key that came with your disc.
https://www.microsoft.com/en-us/software-download/windows10
El-Terrible
Commendable
Apr 27, 2016
48
REgarding the Nvidia video card comments, I don't buy the "Wait for Pascal" movement. The tech is firstly so new there are bound to be issues. The first release will probably be the 1080 which will offer the same performance or very slightly better than a 980Ti with no end of teething problems and the price tag to boot. The fact it's May and still no release date leads me to believe end of Q3 is more likely. By the time the 1080Ti comes out it will probably be closer to the end of the year.
Unless you're desperate for 4k gaming and are hoping a single card will fit all, I see no reason in waiting. If you're happy with 1440p (which most people don't yet game on), get a 980Ti, teamed up with a Skylake and you are future proofed for a long time...plus you can always SLI it down the line if your motherboard supports it (which most good Z170 motherboards will), by which time they'll be much cheaper and probably still a saving over a single 1080Ti without the waiting - just my thoughts
AzaPattaz
38
So guys, taking all of your wonderful advice into consideration, do you think this would be a good computer to suit my needs. I will probably want to OC in the future and If I rack up enough money, buy a VR Headset.
Ari3l
114
22
No, you shouldn't. Motherboards come with atleast 2 of them.
But if you mean whe you just want to buy a separate HDD later, yeah. buy them, or steal them from highschool (i swear it was only once)
Ari3l
114
22
Nice, except i'd recommend a 390 over a 970 any day (8gb vram, better performance at 1440p and the 970 having shadowplay and a lower tdp) but with that tier 4 PSU i'd stick with the 970.
(the CX line isn't that great, some people have bad experiences and some good, i've had a CX 430 for 3 years now)
AzaPattaz
38
What do you mean by Tier 4? Sorry, I'm new to this
Similar threads
