Hydraathond :
Hey,
I need some help choosing a CPU for a media pc/NAS server build. This thing is going to be hooked up to my projector (1080p) running KODI (not as OS, it will just run win 10 so it can function as a normal pc when it needs to) and it is probabably going to be on 24/7 downloading stuff. It also needs to stream movies to other KODI devices in the house.
So i'll be honest I have no idea what kind of power a thing like that needs (I only have experience building high end gaming rigs)
at first I had an i5-6400 in mind but that may be over the top ?
other CPU's I found:
i3-6100
AMD A8-7600 ( I have no experience with AMD never owned one in my life. is their on board graphics decent enough ? this one uses more power, is this something I need to consider ?)
Or any other suggestions ?
I dont really have a budget for this thing, It just needs to do its thing, and do it well, for the best price.
Thanks in advance,
Hydraathond,
From a cost /performance /reliability view, the best CPU today for your use is a used
Xeon E5-2670. This is an LGA2011, dual-CPu capable 8-core @ 2.6 / 3.33GHz. There is currently an over supply of these and on Ebahhh, they are
selling for $60-70. These cost $1,550 new and were used in fairly high end servers. With 8 -core /16.threads they are good VM or CPU rendering and have ultra-high reliability. The Passmark single-threaded rating is 1613 which is fast enough for 3D modeling.
The most economical way to set up a fast, reliable system is probably to buy a used workstation:
Dell Precision T3600 Xeon E5-1603 2.80GHz 4GB 500GB HDD W/ [FirePro V4900] > sold for $349 or offer
That example is a complete system and even the Firepro V4900 GPU is just fine for your use. I have a V4900 and the performance in CAD is not bad at all- similar to a Quadro 2000. Change the CPU to the E5-2670, add RAM to have 16GB and add drives. Run the system off of a 250GB SSD and add a couple of mech'l storage drives to the capacity you feel you need. Use 4GB as the size for a two hour HD movie and a music CD is 700MB. You can set up a domain or workgroup network in Windows and run to switches in room with more than one device.
Another candidate for this use is a used HP z420;
HP Z420 Xeon Workstation E5-1603 2.8GHz 4GB 1TB HHD NVidia Quadro 400 > sold for $280.
That one happens to have an E5-1620 a better CPU- a fast CAD CPU- 4-core @ 3.6./3.8 and the Quadro 400 is minimal, but would be fine for your use. I have two HP z420 (2013 and 2015) and these have very good performance, been 100% reliable and are very quiet-running.
Cheers,
BambiBoom
Modeling:
1. HP z420 (2015) > Xeon E5-1660 v2 (6-core @ 3.7 / 4.0GHz) > 32GB DDR3 1866 ECC RAM > Quadro K4200 (4GB) > Intel 730 480GB (9SSDSC2BP480G4R5) > Western Digital Black WD1003FZEX 1TB> M-Audio 192 sound card > 600W PSU> > Windows 7 Professional 64-bit > Logitech z2300 speakers > 2X Dell Ultrasharp U2715H (2560 X 1440)>
[ Passmark Rating = 5064 > CPU= 13989 / 2D= 819 / 3D= 4596 / Mem= 2772 / Disk= 4555]
[Passmark V9.0 Beta Rating = 5019.1 > CPU= 14206 / 2D= 779 / 3D= 5032 / Mem= 2707 / Disk= 4760] 3.31.16
[Cinebench R15 > CPU = 1014 OpenGL= 126.59 FPS] 7.8.15
Rendering:
2. Dell Precision T5500 (2011) (Revised) > 2X Xeon X5680 (6-core @ 3.33 / 3.6GHz), 48GB DDR3 1333 ECC Reg. > Quadro K2200 (4GB ) > PERC H310 / Samsung 840 250GB / WD RE4 Enterprise 1TB > M-Audio 192 sound card > Logitech z313 > 875W PSU > Windows 7 Professional 64> HP 2711x (27", 1920 X 1080)
[ Passmark system rating = 3844 / CPU = 15047 / 2D= 662 / 3D= 3550 / Mem= 1785 / Disk= 2649] (12.30.15)
3.HP z420 (2013) > Xeon E5-1620 four core @ 3.6 /3.8GHz > 24GB DDR3 ECC 1600 RAM > AMD V4900 (1GB) > Seagate 500GB > Linksys WMP600N WiFi
[Passmark system rating = 2372 / CPU = 9001 / 2D= 712 / 3D= 1353/ Mem= 2261 / Disk= 712]
