Hello!
I've just started putting together a mini ITX pc (https://pcpartpicker.com/list/HjGYdm) using the ASUS Rog Strix Gaming B450-I with a Ryzen 5 3400G.
I need 32GB since I intend to use it solely using the onboard Vega graphics I'd like to get the fastest ram possible (low latency). Size may be an issue as the build is housed in a small case (Elite 110).
I originally went with a G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3200 Memory kit but using XMP it complains and defaults to 2000mhz. The Rog Strix b450-i Doesn't have a QVL for Picasso CPUs so I went with this ram as it was on the QVL for both the Ryzen 3000 series and 2400G CPUs.
I've contacted ASUS asking them to suggest a memory QVL for Picasso chips on this mobo but until then...
What memory do you suggest I should I try instead (Samsung B-die) that will give me roughly 3000mhz and a decent latency?
Many thanks for your thoughts!
