[SOLVED] Need help choosing Gpu
Aug 28, 2021
Hi guys. Im new to this forum and would like your help choosing a Gpu for my new build.
My specs are:
  • Intel core i5 10600kf
  • Asus ROG Strix Z490i gaming
  • Crucial Ballistix 16gb ram 3200mhz CL16
  • Western Digital 1tb nvme SSD
  • Cooler Master Masterwatt 750w PSU 80+ bronze (model MPX-7501-AMAAB)
  • Dell 27" monitor 1440p at 75hz
I'm just a casual gamer, was thinking about buying a rtx 3060 for 500€ or a 3060 ti for 600€. I live in Portugal.
What do you guys think?
Thnx
Lutfij
Make and model of the PSU, as well as it's age? 750W is the wattage, while 80+ bronze is it's 80+ efficiency rating. With your specifications, in order to balance the build, you should look at an RTX 3060Ti. Where in Europe are you located, exactly? This helps us narrow down options.
Aug 31, 2021
26
I would say go for 3060Ti... I mean, 100 euros isn't small, but.. In Serbia, these cards cost about 900 to 1k euros. 6 bucks for 3060ti isn't that bad after all
