Hi, I'm putting together a new system and it will look like this
Evga nForce 780i SLI 775 A1 Version
Intel Core 2 Duo E6850 not sure if I should wait for Penryn or not
2 x EVGA E-GEFORCE 8800GTS Crysis Edition 670MHZ 512MB
RAM - I have no idea there are to many choices.
Basically I want the ablility to overclock at some point and since I'm going SLI do I need speacial SLI memory? Also can I get a good overclock with 6400 or should I go to 8500? And last question does it matter if I buy C4 or C5 memory or are they both about the same performance?
I've been told these are good but not sure what you guys think
Crucial Ballistix Tracer DDR2 PC2-8500 2GB 2X1GB DDR2-1066 CL5-5-5-15 Dual Channel Memory Kit W/ LED (BL2KIT12864AL1065)
and
Crucial Ballistix PC2-8500 DDR2 2GB 2X1GB DDR2-1066 CL5-5-5-15 240PIN DIMM Dual Channel Memory Kit (BL2KIT12864AA1065)
Any input on what memory to buy would be very much appreciated.
Thanks and Happy New Year.
and
