Z ZooSe Honorable Jan 10, 2014 5 0 10,510 Jan 30, 2014 #1 Ok so here is my specs: Case: Micro ATX Inwin Dragon Slayer Intel i5 4670 @ 3.4Ghz Corsair 16Gb Ram @ 1600Mhz EVGA 660 GTX 2Gb (x2) Corsair CS750M PSU Just need help choosing between these 2 motherboards: http:// http://
Solution aevm Jan 30, 2014 Micro atx case with two graphic cards... If you haven't bought the case yet consider getting something larger. I'd pick the Asus. Features are identical, mind you, but Asus is more reliable IMO.
aevm Illustrious May 18, 2007 11,974 0 41,960 Jan 30, 2014 Solution #2 Micro atx case with two graphic cards... If you haven't bought the case yet consider getting something larger. I'd pick the Asus. Features are identical, mind you, but Asus is more reliable IMO. Upvote 0 Downvote Solution
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Jan 30, 2014 #3 The Gryphon is a killer board , ASUS is the way to go. Upvote 0 Downvote
Z ZooSe Honorable Jan 10, 2014 5 0 10,510 Jan 31, 2014 #4 Thanks guys. Asus it is, already had the 2gfx cards in the case, it says micro atx case but there is plenty of room for 2 and great air flow plus lots of fans. But my mobo was faulty hence the new one. Thanks guys. Upvote 0 Downvote
