I want to build my first computer, and I want it to be a very long-lasting machine with durable and sturdy parts. I want it to last me until at least the generation after Skymont.
Approximate Purchase Date: soon, because some nice sales are expiring at the end of the month
Budget Range: $1000, but the closer to $800 the better
System Usage from Most to Least Important: Gaming, day to day productivity, Adobe Creative Suite
Are you buying a monitor: No
Parts to Upgrade: http://pcpartpicker.com/user/turtlefu/saved/1Mml
The HDD I am re-using is a Seagate 500 GB 7200 SATA II, and there is a 1 TB Samsung 7200 rpm SATA II storage drive as well
Do you need to buy OS: No, I have an old hard drive with Windows 7 Retail installed that SHOULD work if I bring it into the new system
Preferred Website(s) for Parts: I prefer Newegg and MicroCenter
Parts Preferences: This is a Haswell build, I prefer Nvidia graphics because they run cooler and use less energy, and I prefer SeaSonic brand or manufactured PSUs
Overclocking: Yes, to about 4.5 GHz hopefully
SLI or Crossfire: Maybe, I was thinking by the time the 800/900 series comes out I could buy a second 760 for cheap and use it to increase performance
Your Monitor Resolution: 1440x900, but I have a 1080p HDTV I would like to try hooking it up to as well.
Why Are You Upgrading: I can't run many games well that I already bought (ie The Witcher, Alan Wake, Bioshock Infinite, Assassin's Creed) I would also like to play the PCSX2 and Dolphin emulators
Parts I need help on:
Cooler - CM Hyper 212 EVO is $30 after MIR, Seidon 120M is $35 after MIR. Reviews say Seidon has better cooling than Hyper 212 EVO by about 4-6 degrees. Since I want to overclock, is the AIO watercooling system worth it? Or are there risks and is the Hyper 212 EVO good enough?
Motherboards - following motherboards are on sale at my local MicroCenter
MSI Z87-G41 for $60
ASRock Z87 Pro4 for $75
Gigabyte GA-Z87-D3HP for $90
MSI Z87-G45 for $100
ASRock Z87-Extreme4 for $105
ASUS Z87-A for $110
Gigabyte GA-Z87X-UD4H for $140
ASUS Z87 Sabertooth for $220
Which is the best deal and value? I may or may not SLI and if there is poor on-chip audio I may buy a sound card. Above all else, I want high-quality, durable, long-lasting motherboard. I have doubts about MSI because I have one of their AM3 motherboards and it is buggy. Sabertooth seems overpriced, and the Extreme4 has poor reviews due to a BIOS issue. I'm drawn towards the G45 except it's an MSI and I like the UD4H because it seems sturdy and long-lasting but it's more expensive than I wanted to spend.
Cases - choice is between Corsair 500R, Fractal Design Define R4, or Enermax Ostrog GT. Corsair seems to have best cooling but Define R4 has better noise suppression. Ostrog GT is in the middle. Thoughts?
PSU: XFX Bronze 750W Modular is SeaSonic-made and is on sale for $55. SeaSonic 750W Bronze Modular is $87. I want 750W in case I SLI, but if I decide to not SLI then I could go for SeaSonic 550W Gold PSU for $80.
MSI Z87-G41 for $60
ASUS Z87-A for $110
