Need help choosing power supply with this case.
Zarien
22
Hey everyone,
My friend is looking to upgrade some of his components and I'm helping him out.
The computer case he was looking at is http://www.newegg.com/Product/Product.aspx?Item=N82E16811147107
The power supply I was looking at for him is this onehttp://www.newegg.com/Product/Produ...yMark=False&IsFeedbackTab=true#scrollFullInfo
Does this look like a good power supply for that case? He can't afford much more than that power supply. Does anyone know if there are some better ones out there in the same price range?
Thanks again for any help!!!
D
Deleted member 217926
Guest
^ This.
You don't buy a power supply for a case you buy a power supply based on the components you are powering.
That Seasonic is an excellent model though.
Zarien
22
I know the case has no real effect. I was putting it there to see if there were any other opinions on better cases bang for your buck wise and to give a better idea of power supply sizes for the case. His old comp was a subpar mess of an HP he had purchased and I am just upgrading some of his components because his graphics card died on him and I'm giving him my old gtx 285. His old case was so small I couldn't fit anything bigger than a gtx 9800 in it.
