Need help choosing PSU
soloby
107
I will be building a computer and I am looking for a good PSU..
my build will be:
Thermaltake V3 Black Edition
ASUS P8 P67
i5-2500k
CM Hyper 212
GSkill 8gb ddr-3 1333
EVGA gtx 460 1gb soc
I will be overclocking my CPU and GPU a little bit and running dual 1920x1080 on 24"
I don't care if it's modular or not, but I want a good solid brand that will last me a long time around the price range of ~$60
Thanks guys
A GTX460 requires a 450w psu with 24a on the 12v rails.
The OC does not matter much, the graphics card is the driver of your psu needs.
If you look for a 450w unit or better from Seasonic, Antec, Corsair, PC P&C, or XFX you will get a quality unit that satisfies your requirement.
One should cost about $70, and the extra $10 is well worth it to get quality.
The XFX 650w unit will power any single card made today, and is a bargain at $65 after rebate:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207002
Similar threads
