I've been needing to replace my RAM recently (MemTes86+ shows thousands of errors) and I've never done this before as all my PCs have been pre-built. I thought I could choose anything DDR3, but now I realise there's a list of compatible RAM for my motherboard:
http://download.gigabyte.eu/FileList/Memory/memory_ga-h61m-ds2-dvi.pdf
And my motherboard is:
http://uk.gigabyte.com/products/product-page.aspx?pid=4403#ov
Which is has these specs:
2 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory
* Due to a Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than the size of the physical memory installed.
Dual channel memory architecture
Support for DDR3 2200(OC)/1333/1066/800 MHz memory modules
Support for non-ECC memory modules
Support for Extreme Memory Profile (XMP) memory modules
* To support XMP memory, you must install an Intel 22nm (Ivy Bridge) CPU.
(I do have this CPU, I have a Intel Core i5 3450 @ 3.10GHz)
From the list they give, most of it isn't manufactured anymore. I was using 1x8gb, but am looking to get 2x4gb. Can anyone help me choose please? Looking to get a reliable brand (with good RMA) at around £50.
http://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=+2x4gb+ddr3&rh=i%3Aaps%2Ck%3A+2x4gb+ddr3
Many many thanks guys.
