Need help choosing replacement PSU for my system.
inneruniverse
193
Hello. This is my system:
i5 2500k
GTX 560 TI (plan to upgrade to R9 380)
Gigabyte z68
I am looking for a PSU to replace my dying Firepower ZT 750W PSU.
Please give me a recommendation for something 650-750W. I would like to overclock my CPU in the near future so I want some leeway over the recommended 550W required to power the R9 380.
This is what I picked out so far - should I go with one of these or is there something better? I would like the price to remain under 70$ ideally around 50-60 (including the rebate into this price if one exists)
XFX TS Edition PRO650W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207014&cm_re=650w_psu-_-17-207-014-_-Product
Rosewill Hive 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182133&cm_re=750w_power_supply-_-17-182-133-_-Product
Is the XFX TS 650W a T2 power supply on the tier list?
I am looking at the tier list and it only lists the 430w as being T2 and says nothing of the PSUs higher than that.
Also the rebate on it expires tomorrow but says it is valid for orders made until the 30th. Does that mean I can still get the rebate if I purchase today? or does it depend on when the order ships?
Thanks just ordered the 650W XFX
