Hello, i need help, i cant decide if i´ll be better off with reference blower type GPU or aftermarket cooler GPU.
Please take a good look at my rig and advice me the best you can.
I only use my PC for gaming.
I´m trying to get the lowest temp on my GPU´s so they don´t throttle down because of the heat.
I won´t OC them.
I´d also like to know if my PSU will be enough.
I´ve only got a week to decide which model to buy.
I can only get these two models where I live.
2 GTX 980 TI GIGABYTE (GV-N98TG1 GAMING-6GD) and SLI them
http://www.gigabyte.ph/products/product-page.aspx?pid=5472#ov
2 GTX 980 TI MSI (6GD5) and SLI them
http://www.msi.com/product/vga/GTX-980Ti-6GD5.html#hero-overview
My Rig.
Case: NZXT H630
https://www.nzxt.com/product/detail/120-H630.html
- Front Coolers NZXT x 200 mm (2 of them) <=> pulling fresh air inside the case
- Rear Cooler NZXT x 140 mm (only one) <=> pushing hot air outside the case
- Bottom Cooler THERMALTAKE x 140 mm (only one) <=> pulling fresh air inside the case
CPU: I7 4770K overclocked at 4.0 Ghz
CPU Cooler: Corsair Hydro H100i (on top exhaust) <=> pushing hot air outside the case
Motherboard: Maximus GENE HERO VII
RAM: DDR3 GSkill 2x8GB 1866Mhz
SSD: Samsung EVO 850 120 GB
SSD: Samsung EVO 850 500 GB
HDD: WD 1TB Blue.
PSU: NZXT 850w HALE90 V2 Gold.
Thanks.
I won´t OC them.
My Rig.
Case: NZXT H630
HDD: WD 1TB Blue.
Thanks.
