Need help choosing right PSU for GPU Upgrade
Blackshadow007
19
Well hello guys , i am confused to choose a right PSU for my upcoming upgrade of PC .
I have currently these hadware
CPU - AMD FX 8150 Black Edition 3.6 Ghz
MB - Asus Sabertooth 990FX
GPU - Asus 570 GTX Direct CU II
RAM - 2X4GB Gskill Sniper 1600 Mhz
1x LG DVD Optical Drive
1x HDD 1TB WD
PSU - Cooler master 700w Elite series Non certified [ Already Damaged and sent to repair 1 month warranty left lol ]
Fans : 1x 140mm front , 1x 120mm back , 1x 200mm top , 2x 120 mm side and 1x CPU Cooler Fan HYPER 212
Now the new hardware i purchased are 1x Corsair H100i , and as PSU already damaged so i am looking for a new good and strong PSU for my build and also i want to upgrade GPU to Asus Strix 970 GTX Single and RAM to Dominator Platinum 2x8GB 1600Mhz and 1x SSD Upgrade . So i looked for PSU reviews a lot and the decision i came for AX 760 / AX860 / RM 650 / RM 750
Now please guys help me to choose the right one or suggest me a perfect PSU for above build , i did check the Cooler master PSU checker and it gave me result of 453W Power i need approx for my current system build [ 970 GTX included single ] http://coolermaster.outervision.com/PSUEngine2
So please suggest me to choose right PSU which not exceeds my needs , remember i have no wish to overclock my CPU or GPU now or near future too . Also no wish to add more GPU as i am happy with Single GPU setup .
Seasonic platinum is also a good choice , if budget isn't a problem then go for it
otherwise xfx one is the best choice
Thanks for the answers guys and yes i am thinking that too get that RM 650 which is fully Modular too and has 7 years warranty so i guess it will be waste of money if i go for AX Series for Platinum Certified product cause i guess for my build GOLD Certified enough ... am i right ? , also yes i have NO WISH TO OVERCLOCK MY CPU OR GPU EVER .
oh you mean RM and HX/AX way to different according to components like capacitors used ?
hey i am reading more reviews here and there and i found this beast 😛
XFX XTR 650W and XTR 750W
are these good enough too and are these fully Japaneses cap PSUs ? those really look good to me . But need to be sure before i jump in 😛
if this is what you're going for
- http://xfxforce.com/en-us/products/xtr-series-full-modular/xtr-series-750w-psu-p1-750b-befx
then its an awesome choice
yes i am going for that , cause i read lots of review about corsair they do not use fully japan caps in their PSU component so i think i need to move my head towards XFX , i cant look for EVGA cause no service on my country so seeing above config of mine what do u think should i go for XTR 750 or XTR 650 ?
XTR 750 of course
After reading reviews from last night now i am stuck to choose among these 3 to my final choice . Please help me guys to choose the best :)
Seasonic Platinum sERIES SS-660XP2 144$ amazon price << == I am guessing this one 😛
XFX XTR 650W P1-650B-BEFX 99$ Amazon Price
EVGA Supernova 750G2 220-G2-0750-XR 113$ Amazon Price
well thanks for your reply mate but i kept EVGA as third cause of its service availability in my Local :/
Normally I'd say the Supernova G2, but 650w is all you need for your build. 750w is super overkill for your build. Go for the XFX XTR 650
Well i bought Seasonic Platinum 860W and its really bad ass , thanks for your helps :)
