Hey guys,
well, this is my first time here on the CE boards. and here's my problem:
I'm looking to buy a new LCD monitor, since my 16" CRT is starting to get old. Now, I was thinking between the lines of either a 19" or a 20" since my budget is limited to $200-$300.
Here's what I'll really be needing this LCD for:
1- HD gaming on my Xbox 360 (The max resolution is 1360*768, so a 1440*900 monitor will do fine, espicially since my GPU is an old 5700LE for CSS...)
2- Computer gaming on a 5700LE (max playable resolution (25fps) being 1440*900 or somewhere along that..
3- Watching DVDs
So, I did some searching, and found out I needed a LCD with good response time, a good contrast ratio, and good colors.
I found these three, which seem good to me:
http://www.newegg.com/Product/Product.asp?Item=N82E16824236008
http://www.newegg.com/Product/Product.asp?Item=N82E16824116373
http://www.newegg.com/Product/Product.asp?Item=N82E16824009100
Now, out of these, which would you guys recommend? If none of them are good for what I need the LCD for and with my budget, which ones would recommend?
Thanks,
DarkAlien
3- Watching DVDs
Thanks,
DarkAlien
