Need help choosing TWO motherboards
Huskynine
66
Hello, I just found two motherboards for my friend's build. Asus, M5A97 LE R2.0 and Biostar TA970.
I considered the Biostar one because it was in a combo with the FX-6300 where you can save $20. Personally, it isn't much, but if both motherboards are on par, then I'd want to save that extra cash.
Here're the links:
M5A97 LE R2.0
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131872
TA970
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138372
These are the PC specs:
AMD FX-6300
Unknown Motherboard
G.SKILL Ares Series 8GB 1600MHz 2x4GB
GeForce GTX 750 EVGA
Seagate Barracuda 1 TB 7200RPM
Corsair CX 430
Thanks! Please reply ASAP
