Question Need Help Choosing What Pc Part I Should Upgrade Next
GuardianOfKnights
Commendable
Jul 9, 2017
Just wondering what I should upgrade for my PC and I'm struggling to run more modern games on my current rig. I'm not very experienced in PC parts so I could use a hand.
Current Parts:
Motherboard: GA-78LMT-S2
GPU: Radeon RX 580
CPU: AMD FX-6300 Six Core Processor
Ram: 8Gb
I would like to know what the priority for upgrades would be here, as I know this is an outdated PC. Thanks for any and all help.
R_1
Judicious
Herald
GPU is good. keep that
the rest NEED to be replaced as a block, as such the order you buy is up to you.
what is your budget? what is your region? what is the currency? what is your preferred shop?
Stewart_2
16
yip agree your RX 580 is a great gpu so that should be fine for the next few years. Your 780 board is now quite old even for AMD3+ chips. Cheapest option would be a Gigabyte 990x gaming with M.2 and a 8350 8 core chip about £150 ish using your current ram. Else you are talking serious money for cpu mobo and DDr4 ram. do you really need to upgrade that far? I run my 8350 with R9 290 and another with the RX 570 just fine at 1080i and like you considered a new system but why? not until I seriously consider 4k gaming and even then I would use upscaling rather than native 4k out of the box. Your board is Sata 2 and USB 2??? Yip a 990x with M.2 or a SSD with Sata 3 would be a massive upgrade speed wise
R_1
Judicious
Herald
under £200
PCPartPicker Part List
CPU: AMD Ryzen 3 1200 3.1 GHz Quad-Core Processor (£46.65 @ CCL Computers)
Motherboard: MSI B450M PRO-M2 MAX Micro ATX AM4 Motherboard (£82.61 @ Alza)
Memory: Patriot Viper 4 16 GB (2 x 8 GB) DDR4-3000 Memory (£59.99 @ Amazon UK)
Video Card: MSI Radeon RX 580 8 GB ARMOR OC Video Card (Purchased For $0.00)
Total: £189.25
Generated by PCPartPicker 2019-12-05 10:30 GMT+0000
under 200 dollars
CPU: AMD Ryzen 3 1200 3.1 GHz Quad-Core Processor ($57.98 @ Newegg)
Motherboard: MSI B450M PRO-M2 MAX Micro ATX AM4 Motherboard ($74.99 @ B&H)
Memory: Patriot Viper 4 16 GB (2 x 8 GB) DDR4-3000 Memory ($54.99 @ Newegg)
Total: $187.96
Generated by PCPartPicker 2019-12-05 05:30 EST-0500
still a big processing upgrade. DDR 4 and a board that it runs on. the entry model Ryzen gives you myriad upgrade paths later and updated extensions some newer games require.
Reactions: GuardianOfKnights
