I am looking for a new case with the following requirements and was wondering which of the attached three would be the best fit or if you think they are not good choices at all!
requirements:
-ATX Mid Tower
-good cable management
-good air flow
-solid build
-needs to fit a 276mm graphics card
following options:
http://www.newegg.com/Product/Product.aspx?Item=11-119-263
http://www.newegg.com/Product/Product.aspx?Item=11-119-233
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147238&ignorebbr=1
Thanks!
requirements:
-ATX Mid Tower
-good air flow
-solid build
following options:
Thanks!
