Need help chosing a motherboard!
twood16
21
I am about to purchase all the parts for my new build and mainly i was wondering if this would be a good motherboard to go along with it. Also any other suggestions would be greatly appreciated!
ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.791361.13-157-271
Thermaltake Toughpower Grand TPG-850M 850W ATX 12V v2.3 & SSI EPS 12V v2.92 SLI Certified CrossFire Certified 80 PLUS GOLD Certified Active PFC Power Supply
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.803657
Corsair Force Series GT CSSD-F60GBGT-BK 2.5" 60GB SATA III Internal Solid State Drive (SSD) http://www.newegg.com/Product/Product.aspx?Item=N82E16820233193
ZALMAN CNPS9900MAX-B 135mm Long life bearing CPU Cooler Blue LED http://www.newegg.com/Product/Product.aspx?Item=N82E16835118074
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9 http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
EVGA 012-P3-2068-KR GeForce GTX 560 Ti (Fermi) 448 Cores Classified 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814130739
Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
If you like Asrock that's a good MB. I personally don't go for Asrock as their power sections are not all that strong.
Also, stay away from Thermaltake PSU's. Go for Corsair, Antec, Seasonic, and XFX.
