G
Guest
Guest
Archived from groups: rec.games.int-fiction (More info?)
Hi,
I have a problem with the Inform parser. I have two objects with names:
Object "Tom's key"
with name 'Tom^s' 'key',
and
Object "my key"
with name 'my' 'key',
now if I wish to refer to the "my key" object by for instance typing "x
my key", the parser proceeds to display "(Tom's key) ..." and goes on
to type that description. It seems that with Inform, as long as the
object is within the player's possession, you can refer to it as "my
(something)" which then refers to Tom's key. There seems to be no way
to refer to the other key unless I define it as "Bob's key" or
something. Is there a way to get around this without using complex
parser routines?
Thanks,
kLy
Hi,
Object "Tom's key"
and
Object "my key"
parser routines?
Thanks,
kLy
