Hello,
Here is the back story to my problem. First, I built this custom PC with a friend about two years ago. Recently - more than in the past - my computer has been freezing. When it was newer this type of thing occasionally happened, but now this is becoming more frequent. When playing games or listening to music, I can start to hear the song/game 'skip'. I dont know how else to describe it, but it happens once, then may go away, a few mins later does it again....getting more and more frequent until the computer freezes. Sometimes I get a BSOD, sometimes the image on screen just freezes while the computer produces a buzzing sounding type of noise, and I have to give the system a hard reset.
I am not sure if this is something related to the timing with my memory - I talked with a friend with a similar problem and he got it sorted out here. I am hoping I can solve this issue too, here is the text from my CPUZ. If there is any other information I am leaving out, please let me know. Thanks for all the help/suggestions!
Best,
Scott
CPU-Z TXT Report
Binaries
CPU-Z version 1.66.1.x64
Processors
Number of processors 1
Number of threads 8
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
-- Core 2
-- Thread 0 4
-- Thread 1 5
-- Core 3
-- Thread 0 6
-- Thread 1 7
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 2.738 MHz
Sys timer 1.000 KHz
BCLK timer 133.50 MHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 8 (max 16)
Name Intel Core i7 930
Codename Bloomfield
Specification Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz
Package (platform ID) Socket 1366 LGA (0x1)
CPUID 6.A.5
Extended CPUID 6.1A
Core Stepping D0
Technology 45 nm
TDP Limit 130 Watts
Core Speed 2936.9 MHz
Multiplier x Bus Speed 22.0 x 133.5 MHz
Rated Bus speed 2402.9 MHz
Stock frequency 2800 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 4-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max turbo frequency 3066 MHz
Max non-turbo ratio 21x
Max turbo ratio 23x
Max efficiency ratio 12x
TDC Limit 110 Amps
Core TDP 110 Watts
Uncore TDP 20 Watts
Power @ 12x 40 Watts
Power @ 13x 46 Watts
Power @ 14x 52 Watts
Power @ 15x 60 Watts
Power @ 16x 68 Watts
Power @ 17x 78 Watts
Power @ 18x 89 Watts
Power @ 19x 101 Watts
Power @ 20x 115 Watts
Power @ 21x 130 Watts
Max bus number 255
Attached device PCI device at bus 255, device 2, function 0
Attached device PCI device at bus 255, device 3, function 4
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020001h
Max CPUID level 0000000Bh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 16 thread(s)
CPUID
0x00000000 0x0000000B 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000106A5 0x00100800 0x0098E3BD 0xBFEBFBFF
0x00000002 0x55035A01 0x00F0B2E4 0x00000000 0x09CA212C
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x00C0003F 0x0000007F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x03C0003F 0x00001FFF 0x00000002
0x00000005 0x00000040 0x00000040 0x00000003 0x00001120
0x00000006 0x00000003 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000044 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x28100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x37692029 0x55504320 0x20202020 0x20202020
0x80000004 0x30333920 0x20402020 0x30382E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00000C00 0x00011501
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040008
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x16161617
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001AC 0x00000000 0x03700410
MSR 0x000001FC 0x00000000 0x00000003
MSR 0x00000300 0x00000000 0xE0000001
MSR 0x0000019C 0x00000000 0x882F0000
MSR 0x000001A2 0x00000000 0x00641400
MSR 0xC0000103 0x00000000 0x00000000
MSR 0x00000198 0x00000000 0x00000016
MSR 0x00000199 0x00000000 0x00000016
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
Type 01020001h
CPUID
0x00000001 0x000106A5 0x01100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000001
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x0000019C 0x00000000 0x882E0000
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01020001h
CPUID
0x00000001 0x000106A5 0x02100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000002
MSR 0x0000019C 0x00000000 0x88300000
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
Type 01020001h
CPUID
0x00000001 0x000106A5 0x03100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000003
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000003
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01020001h
CPUID
0x00000001 0x000106A5 0x04100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000004
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
Type 01020001h
CPUID
0x00000001 0x000106A5 0x05100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000005
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000005
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01020001h
CPUID
0x00000001 0x000106A5 0x06100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000006
MSR 0x0000019C 0x00000000 0x88310000
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 3, Thread ID 1
Type 01020001h
CPUID
0x00000001 0x000106A5 0x07100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000007
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000007
Chipset
Northbridge Intel X58 rev. 13
Southbridge Intel 82801JR (ICH10R) rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 6 GBytes
Channels Triple
Memory Frequency 534.0 MHz (2:8)
CAS# latency (CL) 8.0
RAS# to CAS# delay (tRCD) 8
RAS# Precharge (tRP) 8
Cycle Time (tRAS) 20
Row Refresh Cycle Time (tRFC) 59
Command Rate (CR) 1T
Uncore Frequency 2135.9 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) G.Skill (7F7F7F7FCD000000)
Size 2048 MBytes
Max bandwidth PC3-10700H (667 MHz)
Part number F3-12800CL8-2GBRM
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.1
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-16-22 @ 444 MHz
JEDEC #2 7.0-7-7-19-26 @ 518 MHz
JEDEC #3 8.0-8-8-22-30 @ 592 MHz
JEDEC #4 9.0-9-9-24-33 @ 666 MHz
XMP profile XMP-1600
Specification PC3-12800
Voltage level 1.600 Volts
Min Cycle time 1.250 ns (800 MHz)
Max CL 8.0
Min tRP 10.00 ns
Min tRCD 10.00 ns
Min tWR 12.50 ns
Min tRAS 30.00 ns
Min tRC 42.50 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 8.0-8-8-24-34-2T @ 800 MHz (1.600 Volts)
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.1
AMP no
Max CL 8.0
Min tRP 10.00 ns
Min tRCD 10.00 ns
Min tWR 12.50 ns
Min tRAS 30.00 ns
Min tRC 42.50 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 3
SMBus address 0x54
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.1
AMP no
Max CL 8.0
Min tRP 10.00 ns
Min tRCD 10.00 ns
Min tWR 12.50 ns
Min tRAS 30.00 ns
Min tRC 42.50 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 3C 00
10 6C 78 6C 30 6C 11 20 8C 70 03 3C 3C 00 F0 82 05
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 04 CD 00 00 00 00 00 00 00 AE 0C
80 46 33 2D 31 32 38 30 30 43 4C 38 2D 32 47 42 52
90 4D 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 0C 4A 01 11 01 08 00 00 00 2C 0A 50 10 00 50 50
C0 50 64 10 F0 54 5A 00 70 03 3C 3C 11 2C 3C 00 00
D0 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM # 2
SPD registers
DIMM # 3
SPD registers
Monitoring
Mainboard Model Rampage II GENE (0x000004AE - 0x3E4CCCAC)
LPCIO
LPCIO Vendor Winbond
LPCIO Model W83667HG
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xA5
LPCIO Revision ID 0x13
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 A5 13 FF 00 44 00 00 FE 40 00 00 7F 22 00 00 40
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Winbond W83667HG
Voltage 0 1.10 Volts [0x8A] (CPU VCORE)
Voltage 1 1.71 Volts [0xD6] (VIN1)
Voltage 2 3.36 Volts [0xD2] (+3.3V)
Voltage 3 5.02 Volts [0xD1] (+5V)
Voltage 4 11.88 Volts [0xD5] (+12V)
Voltage 6 0.98 Volts [0x7A] (VIN6)
Temperature 0 43°C (109°F) [0x2B] (SYSTIN)
Temperature 1 37°C (97°F) [0x49] (CPUTIN)
Temperature 2 42°C (106°F) [0x53] (AUXTIN)
Fan 1 1125 RPM [0x4B] (CPUFANIN0)
Hardware registers
bank 0
00 04 9B 04 AE 30 00 46 20 01 9B 01 01 3C 3C 04 04
10 04 FF 30 00 00 01 01 3C 43 17 00 00 2E FF FF DD
20 9F D6 D2 D1 D5 FF 7A 2B FF 3F FF DA 00 D6 1E F6
30 3F 4A 67 7D E9 7F 0E F7 E4 AD A3 FB 76 14 81 FF
40 03 FA 0F FF FF 00 3F 35 2D 24 80 C0 10 95 00 A3
50 FF FF 00 FF FF FF 00 80 C1 6F FF FF 19 E4 00 05
60 04 AE 50 00 01 01 3C FF 0A FF 01 FF FF FF FF 15
70 24 33 33 33 34 37 9B FF FF FF FF 4B 22 00 2B FF
80 04 9B 04 AE 30 00 46 20 01 9B 01 01 3C 3C 04 04
90 04 FF 30 00 00 01 01 3C 43 17 00 00 2E FF FF DD
A0 9F D6 D2 D1 D5 FF 7A 2B FF 3F FF DA 00 D6 1E F6
B0 3F 4A 67 7D E9 7F 0E F7 E4 AD A3 FB 76 14 81 FF
C0 03 00 00 FF FF 00 3F 35 2D 24 80 C0 10 95 00 A3
D0 FF FF 00 FF FF FF 00 80 C1 6F FF FF 19 E4 00 05
E0 04 AE 50 00 01 01 3C FF 0A FF 01 FF FF FF FF 15
F0 24 33 33 33 34 37 9B FF FF FF FF 4B 22 00 2B FF
bank 1
50 27 00 00 4B 00 50 04 38 FF FF FF FF FF FF FF FF
bank 2
50 29 80 00 4B 00 50 1B 50 FF FF FF FF FF FF FF FF
bank 3
50 06 02 07 01 03 02 05 00 02 00 00 D0 7F 0A 00 00
bank 4
50 1A 13 FF 00 00 00 00 0D 4F 58 1D 3A 09 5F 20 7F
Hardware monitor Analog Device ASP0800
Current 0 20.44 Amps [0x28E] (CPU)
Power 0 26.22 W [0x347] (CPU)
Register space SMBus, base address = 0x0400
SMBus request channel 0x0, address 0x20
00 ER 80 17 7F ER ER ER ER ER ER ER ER ER ER ER ER
10 00 ER ER ER ER ER ER ER ER B0 ER ER ER ER ER ER
20 20 00 ER ER ER 20 B2 ER ER ER ER ER ER ER ER ER
30 ER ER ER ER ER ER ER ER 74 03 ER ER ER ER ER ER
40 ER ER ER ER ER ER ER ER ER ER 99 ER ER ER ER ER
50 ER ER ER ER ER ER ER ER ER ER ER ER ER ER ER ER
60 ER ER ER ER ER ER ER ER ER ER 2C ER ER ER ER ER
70 ER ER ER ER ER ER ER ER 02 08 00 00 ER ER 82 ER
80 00 ER ER ER ER ER ER ER ER ER ER 35 95 ER ER ER
90 ER ER ER ER ER ER 4D ER ER 41 98 01 ER ER ER ER
A0 ER ER ER ER ER ER ER ER ER ER ER ER ER ER ER ER
B0 ER ER ER ER ER ER ER ER ER ER ER ER ER ER ER ER
C0 ER ER ER ER ER ER ER ER ER ER ER ER ER ER ER ER
D0 00 03 72 72 03 02 01 8E 41 00 00 00 00 00 00 10
E0 00 00 10 10 10 10 10 10 10 10 10 ER 07 ER 00 00
F0 FF 15 ER ER ER 01 02 ER ER CD C0 10 FF ER ER ER
Hardware monitor Asus IROG 01
Voltage 0 1.27 Volts [0x4F6] (CPU)
Voltage 1 1.50 Volts [0x5DD] (DRAM)
Voltage 2 1.11 Volts [0x457] (ICH Core)
Voltage 3 1.50 Volts [0x5DD] (ICH PCIE +1.5V)
Voltage 4 1.82 Volts [0x71B] (CPU PLL)
Voltage 5 1.51 Volts [0x5E4] (IOH PCIE +1.5V)
Voltage 6 1.17 Volts [0x493] (IOH Core)
Voltage 7 1.22 Volts [0x4C8] (QPI)
Fan 1 1131 RPM [0x46B] (CPU)
Fan 2 1047 RPM [0x417] (Chassis #1)
SMBus request channel 0x0, address 0x38
00 FF 72 72 58 89 72 54 FF FF FF FF 00 00 FF FF FF
20 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
30 00 FF FF FF 85 00 51 00 00 40 00 FF FF 00 00 FF
40 FF FF FF FF FF 20 FF FF 00 FF FF FF 00 FF FF FF
50 00 00 00 00 00 00 FF FF FF FF FF 00 FF FF FF FF
60 FF 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF FF FF 27 7F 61 00 12 A2
90 EF 04 E4 05 57 04 DD 05 1B 07 E4 05 8C 04 A7 04
A0 00 00 AB 04 19 04 00 00 FF FF FF FF 46 00 FF FF
B0 FF 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF
C0 00 00 00 00 00 00 00 00 00 A0 FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Best,
Scott
CPU-Z TXT Report
Binaries
Processors
Number of threads 8
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
-- Core 2
-- Thread 0 4
-- Thread 1 5
-- Core 3
-- Thread 0 6
-- Thread 1 7
Timers
Sys timer 1.000 KHz
Processor 1 ID = 0
Codename Bloomfield
CPUID 6.A.5
Extended CPUID 6.1A
Core Stepping D0
Technology 45 nm
TDP Limit 130 Watts
FID/VID Control yes
Max turbo ratio 23x
TDC Limit 110 Amps
Core TDP 110 Watts
Uncore TDP 20 Watts
Max bus number 255
Thread dumps
CPU Thread 0
APIC ID 0
Type 01020001h
CPUID
CPU Thread 1
APIC ID 1
Type 01020001h
CPUID
CPU Thread 2
APIC ID 2
Type 01020001h
CPUID
CPU Thread 3
APIC ID 3
Type 01020001h
CPUID
CPU Thread 4
APIC ID 4
Type 01020001h
CPUID
CPU Thread 5
APIC ID 5
Type 01020001h
CPUID
CPU Thread 6
APIC ID 6
Type 01020001h
CPUID
CPU Thread 7
APIC ID 7
Type 01020001h
CPUID
Chipset
Memory Type DDR3
Channels Triple
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.1
AMP no
Max CL 8.0
Min tRP 10.00 ns
Min tRCD 10.00 ns
Min tWR 12.50 ns
Min tRAS 30.00 ns
Min tRC 42.50 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.1
AMP no
Max CL 8.0
Min tRP 10.00 ns
Min tRCD 10.00 ns
Min tWR 12.50 ns
Min tRAS 30.00 ns
Min tRC 42.50 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 3
SMBus address 0x54
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.1
AMP no
Max CL 8.0
Min tRP 10.00 ns
Min tRCD 10.00 ns
Min tWR 12.50 ns
Min tRAS 30.00 ns
Min tRC 42.50 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 1
SPD registers
DIMM # 2
SPD registers
DIMM # 3
SPD registers
Monitoring
LPCIO
LPCIO Chip ID 0xA5
Config Mode LDN 0xB
Hardware Monitors
Hardware registers
bank 0
bank 1
bank 2
bank 3
bank 4
