Need Help, Computer keeps freezing then restarting during gaming
tztop13
Commendable
Dec 27, 2016
Recently I've upgraded my GPU to a GTX1080 from a GTX970 in order to play in 4K. While playing some of the more resource intensive games (Ark: Survival Evolved, Gears of War 4, and even The Forest), I started to suffer crashes where my computer would freeze with the audio stuck repeating whatever the last sound was when it crashed and I couldn't do anything but hard reset it. If I waited a little while (roughly 30 seconds), my computer seemed to restart itself.
At first I thought it might be my HDD either dying (as there were reviews on the product warning of potential death after a year and it has been two years since I got it) or overheating from having to handle a 4K game at max settings, but I replaced the HDD with a 1TB SSD, but the problem continued. I checked to make sure my NVIDIA driver was up to date, and it was. I thought it might be an issue with it overheating as the problem appeared to occur after a while of gaming (like 30 minutes to 2 hours) and would occur more often if I got back into the game after a crash, but I downloaded HWMonitor and the temperatures weren't very high (will list them at the bottom of the post). So after searching for a while for a solution, I'm suspecting it may be a PSU issue, but I'm not sure and still think a 750W PSU should be sufficient.
Any help with the issue would be greatly appreciated.
Note: I have not OC anything as it has all been sufficient for my needs without being OC. Also, I run the OS on the Kingston SSD and just installed the Samsung 1TB SSD and put all of my games on there. I run all of my games on the 4K monitor and use the 1080 for general use like surfing the web or TS.
My Computer -
OS: Windows 10
MB: MSI X99S MPOWER
CPU: Intel Core i7-5820K Haswell-E 6-Core 3.3 GHz LGA 2011-v3
CPU Cooling: Cooler Master Hyper 212 EVO
PSU: Rosewill CAPSTONE 750M 750W Modular Power Supply (80 PLUS GOLD Certified)
Memory: Ballistix Sport 16GB (4 x 4GB) 288-Pin DDR4 SDRAM
Storage: 2x Seagate Desktop HDD ST1000DM003 1TB 64MB Cache
Kingston Digital 240GB SSD
Samsung 850 EVO 1TB SSD
Graphics Card: MSI GeForce GTX 1080 DirectX 12 GTX 1080 GAMING 8G
Monitors: 4K - ASUS PB287Q Black 28" 1ms
1K - ASUS VN248H-P Slim Bezel Black 23.8" 5ms
Heat Readings from one of the crashes (took a picture of the second screen that had HWMonitor on it when it froze).
MSI X99S MPOWER -
SYSTIN: 45C
CPUTIN: 54C
TMPIN3: 56C
Intel Core i7 5820K -
CORE#0: 56C
CORE#1: 51C
CORE#2: 53C
CORE#3: 54C
CORE#4: 52C
CORE#5: 39C
Package: 56C
Samsung SSD -
Air Flow: 39C
Seagate ST100DM003 1TB -
Assembly: 42C
Air Flow: 42C
Kingston 240GB -
Assembly: 38C
NVIDIA GeForce GTX 1080 -
TMPIN0: 70C
Thanks for the reply. I ran a test with Heaven and had 37.7 FPS on ultra quality and extreme tessellation. it didn't get over 67C during the test either. I've also run FurMark for about 10 minutes without issue, but it pushed my GPU up to around 72C.
Any other suggestions for tests?
