Here is all the spec to the computer:
-Intel E7500 Processor (2.93 GHz) - brand new
-MSI G41TM-E43 Motherbaord - brand new
-4GB DDR2 RAM - brand new
-30 GB HDD - Will upgrade to 500 GB in the next week
-HP DVD Player
Here's the problem:
When trying to power up the system, nothing happens. Everything is in the right place. NOTE: My power supply has a 20-pin plug and the motherboard has a 24-pin adapter. ALSO NOTE: My power supply is about 5 years old, and only has 200W.
Should I upgrade the power supply to something bigger (400W - 500W) or is this something more serious?
If you need more info, just ask.
Thanks.
-HP DVD Player
Here's the problem:
Thanks.
