Need help Computer wont turn on!
Berry30
64
Hi, i just recently made a pc and im having troubles turning it on. As soon as i click the button the pc wont turn on at all, and it not even the psu fan will move. I need help!
The PSU has a flip switch see if it's turned on (I is on O is off)... if it's on I and it the fan doesn't run, the PSU is dead.
Also double check the front panel to motherboard FP header connections. And if they are correctly attached, remove them and jump start the motherboard with a small screwdriver or paper clip used to bridge the two power pins on the motherboard header.
i got it working, turns out i had the psu wires in backwards. But now im getting no signal =/. Ughhhh do u know anything about that?
Hey! sorry for the delay... only now I just checked my mail and noticed you rated the best answer. I never had the thread highlighting and it's not the only time... forum errors for sure.
1. Which wires were backwards, 4/8 pin or 24 pin?...
2. and you mean no video signal (blank screen)?
3. Does it beep, more than one beep, or nothing; a few seconds after you press the power button?.
I got everything fixed a while ago. I put the wires in the wrong way xD. Thanks for the help though.
