need help connecting razer tiamat 7.1 to PS4
Uhm http://www.razerzone.com/gaming-audio/razer-tiamat-71 states
"System Requirements
PC with built-in 3.5mm audio jacks & 1 USB port
7.1 Surround Sound-enabled Sound Card (for 7.1 Mode)" So it is NOT PS4 compatible.
http://www.asus.com/us/Sound_Cards/Xonar_U7/specifications/ states
"Operating System
Windows® 8 , 32bit/64bit
Windows® 7 , 32bit/64bit
Windows® XP , 32bit/64bit
Mac OS X *" So it is NOT PS4 compatible.
http://us.creative.com/p/sound-blaster/sound-blaster-e1 states
"Connect the Sound Blaster E1 to your PC or Mac, and fire up Sound Blaster E-Series Control Panel."
You have bought all PC / Mac hardware for the wrong system (PS4). You should SEEK PS4 certified accessories.
