So I have this computer https://www.newegg.com/Product/Product.aspx?Item=N82E16883102105 and it runs really hot. I would like to ask all of you for your knowledge in helping me find the stuff I need to keep it cool while gaming!
Edit: It is running around 100C (51 idle) and will beep after a while. I already had one GPU meltdown and had to replace it (same gpu). I also took off the side of the case to allow for better airflow.
