Question Need help, CPU overheating with low usage or apparent cause.
Sep 25, 2020
22
Hello everyone. I recently sent my computer to cleaning, changing the thermal paste on my PC, and replace a rear fan on my cabinet, but since it is back I noticed something weird. Even just opening some browser tabs the CPU heats to 60º-70º and when I try anything a little more demanding it peaks to 90º-100º (Just like opening a VM or a simple game). I noticed looking at the task manager that the CPU usage is not high, less than 30% is enough to create those peeks. At 10% it is already going to 70º-80º!
I would really appreciate it if anyone can give me some help with it. I run an HViNFO Report last week before doing the repairs and another one today and the most significant difference I saw on those reports about the CPU is the IccMax (which I don't know what it is. If anyone can help me understand). Please I'll be glad to get any help on finding the issue, I'll paste the reports highlighting the differences here if anyone could help.
The report on the CPU before the problem:
Intel Core i7-7700
[General Information]
Processor Name:Intel Core i7-7700
Original Processor Frequency:3600.0 MHz
Original Processor Frequency [MHz]:3600
CPU ID:000906E9
CPU Brand Name:Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
CPU Vendor:GenuineIntel
CPU Stepping:B0
CPU Code Name:Kaby Lake-S
CPU Technology:14 nm
CPU S-Spec:SR338
CPU Thermal Design Power (TDP):65.0 W
CPU Power Limits (Max):Power = Unlimited, Time = Unlimited
CPU Power Limit 1 - Long Duration:Power = 65.00 W, Time = 8.00 sec [Unlocked]
CPU Power Limit 2 - Short Duration:Power = 81.25 W, Time = 2.44 ms [Unlocked]
CPU Max. Junction Temperature (Tj,max):100 °C
CPU Type:Production Unit
CPU Platform:Socket H4 (LGA1151)
Microcode Update Revision:B4
Number of CPU Cores:4
Number of Logical CPUs:8
[Operating Points]
CPU LFM (Minimum):800.0 MHz = 8 x 100.0 MHz
CPU HFM (Base):3600.0 MHz = 36 x 100.0 MHz
CPU Turbo Max:4200.0 MHz = 42 x 100.0 MHz [Unlocked]
Turbo Ratio Limits - IA/SSE:42x (1c), 41x (2-3c), 40x (4c)
Turbo Ratio Limits - AVX2, Resolved:42x (1c), 41x (2-3c), 40x (4c)
CPU Current:4090.0 MHz = 41 x 99.8 MHz @ 1.1821 V
LLC/Ring Maximum:3900.0 MHz = 39.00 x 100.0 MHz
LLC/Ring Current:3790.7 MHz = 38.00 x 99.8 MHz
System Agent Current:997.6 MHz = 10.00 x 99.8 MHz
CPU Bus Type:Intel Direct Media Interface (DMI) v3.0
Maximum DMI Link Speed:8.0 GT/s
Current DMI Link Speed:5.0 GT/s
Ring to Core Offset:Enabled
[IA Overclocking]
Voltage Offset:Supported
Voltage Override:Supported
Ratio Overclocking:Not Supported
Fused Ratio Limit:42x
OC Ratio Limit:N/A
Voltage Mode:Interpolative
Voltage Offset:0 mV
IccMax:90.00 A
[GT (Slice) Overclocking]
Fused Ratio Limit:23x
OC Ratio Limit:N/A
Voltage Offset:0 mV
IccMax:101.00 A
[CLR (CBo/LLC/Ring) Overclocking]
Fused Ratio Limit:39x
OC Ratio Limit:N/A
Voltage Offset:0 mV
IccMax:90.00 A
[GT (Unslice) Overclocking]
OC Ratio Limit:N/A
Voltage Offset:0 mV
IccMax:101.00 A
[Uncore/SA Overclocking]
Voltage Override:Not Supported
Fused Ratio Limit:N/A
OC Ratio Limit:N/A
Voltage Offset:0 mV
IccMax:20.00 A
[Cache and TLB]
L1 Cache:Instruction: 4 x 32 KBytes, Data: 4 x 32 KBytes
L2 Cache:Integrated: 4 x 256 KBytes
L3 Cache:8 MBytes
Instruction TLB:2MB/4MB Pages, Fully associative, 8 entries
Data TLB:4 KB Pages, 4-way set associative, 64 entries
[Standard Feature Flags]
FPU on ChipPresent
Enhanced Virtual-86 ModePresent
I/O BreakpointsPresent
Page Size ExtensionsPresent
Time Stamp CounterPresent
Pentium-style Model Specific RegistersPresent
Physical Address ExtensionPresent
Machine Check ExceptionPresent
CMPXCHG8B InstructionPresent
APIC On Chip / PGE (AMD)Present
Fast System CallPresent
Memory Type Range RegistersPresent
Page Global FeaturePresent
Machine Check ArchitecturePresent
CMOV InstructionPresent
Page Attribute TablePresent
36-bit Page Size ExtensionsPresent
Processor NumberNot Present
CLFLUSH InstructionPresent
Debug Trace and EMON StorePresent
Internal ACPI SupportPresent
MMX TechnologyPresent
Fast FP Save/Restore (IA MMX-2)Present
Streaming SIMD ExtensionsPresent
Streaming SIMD Extensions 2Present
Self-SnoopPresent
Multi-Threading CapablePresent
Automatic Clock ControlPresent
IA-64 ProcessorNot Present
Signal Break on FERRPresent
Virtual Machine Extensions (VMX)Present
Safer Mode Extensions (Intel TXT)Present
Streaming SIMD Extensions 3Present
Supplemental Streaming SIMD Extensions 3Present
Streaming SIMD Extensions 4.1Present
Streaming SIMD Extensions 4.2Present
AVX SupportPresent
Fused Multiply Add (FMA)Present
Carryless Multiplication (PCLMULQDQ)/GFMULPresent
CMPXCHG16B SupportPresent
MOVBE InstructionPresent
POPCNT InstructionPresent
XSAVE/XRSTOR/XSETBV/XGETBV InstructionsPresent
XGETBV/XSETBV OS EnabledPresent
Float16 InstructionsPresent
AES Cryptography SupportPresent
Random Number Read Instruction (RDRAND)Present
Extended xAPICPresent
MONITOR/MWAIT SupportPresent
Thermal Monitor 2Present
Enhanced SpeedStep TechnologyPresent
L1 Context IDNot Present
Send Task Priority Messages DisablingPresent
Processor Context IDPresent
Direct Cache AccessNot Present
TSC-deadline TimerPresent
Performance/Debug Capability MSRPresent
IA32 Debug Interface SupportPresent
64-Bit Debug StorePresent
CPL Qualified Debug StorePresent
[Extended Feature Flags]
64-bit ExtensionsPresent
RDTSCP and TSC_AUX SupportPresent
1 GB large page supportPresent
No ExecutePresent
SYSCALL/SYSRET SupportPresent
Bit Manipulation Instructions Set 1Present
Bit Manipulation Instructions Set 2Present
Advanced Vector Extensions 2 (AVX2)Present
Advanced Vector Extensions 512 (AVX-512)Not Present
AVX-512 Prefetch InstructionsNot Present
AVX-512 Exponential and Reciprocal InstructionsNot Present
AVX-512 Conflict Detection InstructionsNot Present
AVX-512 Doubleword and Quadword InstructionsNot Present
AVX-512 Byte and Word InstructionsNot Present
AVX-512 Vector Length ExtensionsNot Present
AVX-512 52-bit Integer FMA InstructionsNot Present
Secure Hash Algorithm (SHA) ExtensionsNot Present
Software Guard Extensions (SGX) SupportPresent
Supervisor Mode Execution Protection (SMEP)Present
Supervisor Mode Access Prevention (SMAP)Present
Hardware Lock Elision (HLE)Present
Restricted Transactional Memory (RTM)Present
Memory Protection Extensions (MPX)Present
Read/Write FS/GS Base InstructionsPresent
Enhanced Performance String InstructionPresent
INVPCID InstructionPresent
RDSEED InstructionPresent
Multi-precision Add Carry Instructions (ADX)Present
PCOMMIT InstructionsNot Present
CLFLUSHOPT InstructionsPresent
CLWB InstructionsNot Present
TSC_THREAD_OFFSETPresent
Platform Quality of Service Monitoring (PQM)Not Present
Platform Quality of Service Enforcement (PQE)Not Present
FPU Data Pointer updated only on x87 ExceptionsNot Present
Deprecated FPU CS and FPU DSPresent
Intel Processor TracePresent
PREFETCHWT1 InstructionNot Present
AVX-512 Vector Bit Manipulation InstructionsNot Present
AVX-512 Vector Bit Manipulation Instructions 2Not Present
AVX-512 Galois Fields New InstructionsNot Present
AVX-512 Vector AESNot Present
AVX-512 Vector Neural Network InstructionsNot Present
AVX-512 Bit AlgorithmsNot Present
AVX-512 Carry-Less Multiplication Quadword (VPCLMULQDQ)Not Present
AVX-512 Vector POPCNT (VPOPCNTD/VPOPCNTQ)Not Present
User-Mode Instruction PreventionNot Present
Protection Keys for User-mode PagesNot Present
OS Enabled Protection KeysNot Present
Wait and Pause Enhancements (WAITPKG)Not Present
Total Memory EncryptionNot Present
Read Processor IDNot Present
Cache Line DemoteNot Present
MOVDIRI: Direct StoresNot Present
MOVDIR64B: Direct StoresNot Present
ENQCMD: Enqueue StoresNot Present
SGX Launch ConfigurationNot Present
Control-Flow Enforcement Technology (CET) Shadow StackNot Present
AVX-512 4 x Vector Neural Network Instructions Word Variable PrecisionNot Present
AVX-512 4 x Fused Multiply Accumulation Packed Single PrecisionNot Present
Fast Short REP MOVNot Present
AVX-512 VP2INTERSECT SupportNot Present
MD_CLEAR SupportPresent
Hybrid ProcessorNot Present
Platform Configuration (PCONFIG)Not Present
Indirect Branch Restricted Speculation (IBRS), Indirect Branch Predictor Barrier (IBPB)Present
Single Thread Indirect Branch Predictors (STIBP)Present
L1D_FLUSH SupportPresent
IA32_ARCH_CAPABILITIES MSRNot Present
IA32_CORE_CAPABILITIES MSRNot Present
Speculative Store Bypass Disable (SSBD)Present
Control-Flow Enforcement Technology (CET) Indirect Branch TrackingNot Present
Advanced Matrix Extensions (AMX) Tile ArchitectureNot Present
Advanced Matrix Extensions (AMX) bfloat16 SupportNot Present
Advanced Matrix Extensions (AMX) 8-bit Integer OperationsNot Present
AVX-512 BFLOAT16 InstructionsNot Present
[Enhanced Features]
Thermal Monitor 1:Supported, Enabled
Thermal Monitor 2:Supported, Enabled
Enhanced Intel SpeedStep (GV3):Supported, Enabled
Bi-directional PROCHOT#:Enabled
Extended Auto-HALT State C1E:Enabled
MLC Streamer PrefetcherSupported, Enabled
MLC Spatial PrefetcherSupported, Enabled
DCU Streamer PrefetcherSupported, Enabled
DCU IP PrefetcherSupported, Enabled
Intel Dynamic Acceleration (IDA) Technology:Not Supported
Intel Dynamic FSB Switching:Not Supported
Intel Turbo Boost Technology:Supported, Enabled
Programmable Ratio Limits:Supported, Disabled
Programmable TDC/TDP Limits:Supported, Disabled
Hardware Duty Cycling:Supported, Enabled
[CPU SKU Features]
Display HD Audio:Supported
DMI x4 Width:Supported
DRAM ECC:Not Supported
VT-d:Supported
DMI in Gen2 Mode:Supported
PEG in Gen2 Mode:Supported
1N Mode DDR Timings:Supported
Camarillo (DTT) Device:Supported
2 DIMMs per Channel:Not Supported
X2APIC:Supported
Dual Memory Channel:Supported
Integrated GPU (IGD):Enabled
DDR Overclocking:Disabled
Overclocking by DSKU:Disabled
DDR3L:Supported
Maximum Memory Size per Channel:64 GB (unlimited)
Hyper-Threading (SMT):Supported
Additive Graphics:Supported
Additive Graphics:Enabled
PCIe Gen 3:Supported
DMI Gen 3:Supported
HDCP:Supported
DDR4:Supported
LPDDR3:Not Supported
BCLK OC Limit:100 MHz
Maximum Supported LPDDR3 Frequency:1600 MHz
Maximum Supported DDR4 Frequency:1200 MHz
SVID Status:Enabled
[Voltage Regulator (SVID)]
VCC VR:ON Semi (0x5b), IMVP8
VR Thermal Sensor:Supported
[Memory Ranges]
Maximum Physical Address Size:39-bit (512 GBytes)
Maximum Virtual Address Size:48-bit (256 TBytes)
[MTRRs]
Range E0000000-100000000 (3584MB-4096MB) Type:Uncacheable (UC)
Range D0000000-E0000000 (3328MB-3584MB) Type:Uncacheable (UC)
Range C8000000-D0000000 (3200MB-3328MB) Type:Uncacheable (UC)
And the report on CPU after the problem:
Intel Core i7-7700
CPU ID:000906E9
CPU Stepping:B0
CPU S-Spec:SR338
CPU Power Limit 1 - Long Duration:Power = Unlimited, Time = 8.00 sec [Unlocked]
CPU Power Limit 2 - Short Duration:Power = Unlimited, Time = 2.44 ms [Unlocked]
[Operating Points]
CPU Current:4102.0 MHz = 41 x 100.0 MHz @ 1.2240 V
LLC/Ring Current:3801.9 MHz = 38.00 x 100.0 MHz
System Agent Current:1000.5 MHz = 10.00 x 100.0 MHz
[IA Overclocking]
OC Ratio Limit:N/A
Voltage Offset:0 mV
IccMax:255.50 A
OC Ratio Limit:N/A
Voltage Offset:0 mV
IccMax:255.50 A
OC Ratio Limit:N/A
Voltage Offset:0 mV
IccMax:255.50 A
OC Ratio Limit:N/A
Voltage Offset:0 mV
IccMax:255.50 A
OC Ratio Limit:N/A
Voltage Offset:0 mV
IccMax:20.00 A
[Cache and TLB]
L3 Cache:8 MBytes
FPU on ChipPresent
Self-SnoopPresent
AVX SupportPresent
No ExecutePresent
[Enhanced Features]
[CPU SKU Features]
VT-d:Supported
X2APIC:Supported
DDR3L:Supported
DMI Gen 3:Supported
HDCP:Supported
DDR4:Supported
SVID Status:Enabled
[Memory Ranges]
[MTRRs]
I feel your CPU heatsink/cooler is not properly installed.
Hi ben001 thank you for your reply. Is there any way I can check to see if its the installation? Is there something I can run to see if there is an issue on it? Thank you
Hi, :)
Yes, you can see if the heatsink pins are inserted evenly in those mounting holes on your motherboard. The best viewing angle will be from the rear side of your mobo.
Thank you, was exactly that, the pins were not even after removing and installing again the problem is gone!
Reactions: RodroX
