Hey guys I’m one of those weirdos still playing on a PS3. I’m ready to make the leap to next gen, and I really want to do it on a gaming PC. But I’m afraid of buying a PC for twice or more the price of the PS4 getting it home hooking it up only to find out it can’t run games as well as the PS4! I have my eye on two builds in particular and any advice would be awesome!
First is Digital Storm Vanquish 3 Level 1
Main specs
GPU NVIDIA GTX 960 2GB
CPU Intel Core i3 4370 CPU
RAM 8GB 1600MHz
1TB 7200RPM HDD
The second is the Syber Vapor which you can fully customize on CyberPowerPC’s website before ordering. My questions about this PC are:
Are any of these processors competent for running games on high 1080
Athlon X4 740
Athlon X4 840
Intel® Pentium™ Anniversary Edition G3258
And will a GTX 960 2GB matched with these CPU be enough to beat PS4 or do I have to go to a GTX970 or what cards from AMD would work?
Thx for any help!!
P.S.
I know I might get advice to build my own pc or step up to Vanquish level 3 which is over $1200 Please keep in mind that I am a PC gaming newb and don’t want to build a PC or spend exorbitantly more then I would for a counsel thx!
Main specs
RAM 8GB 1600MHz
1TB 7200RPM HDD
Athlon X4 740
Athlon X4 840
Thx for any help!!
P.S.
