Hello, im planing on buying a new gaming laptop during this period and im currently stuck between these 2. They are both priced at 1000 pounds here in the uk currently.
The first is Asus TUF FX705DU-AU035T Ryzen 7-3750H - 16GB ddr4 2666Mhz - 256GB SSD + 1TB HDD - 17.3 Inch - GTX 1660Ti 6GB
The second is ACER Nitro 5 AN517-51 Intel® Core™ i7-9750H - 8GB ddr4 2600Mgh - 1 TB HDD & 256 SSD - 17.3 Inch - GTX 1660 Ti 6GB
The Acer seems to have the superior CPU but im also concerned about the overall build quality, im wondering if its a small or big difference. And im planing on replacing the ram on either with a dual channel 16+16 ram after i get it.
