Need help deciding case
hystr
15
Hello I have all my stuff picked out but these new cases keep popping up and I need expericed opiions on this.
I am looking at getting either a:
Cooler Master Storm Trooper
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119245
or
Thermaltake Overseer RX-1
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133194
What I'm looking for is: good fan air travel, keeps system at good tempeture, spacious I have an Asus 6970 DCII video card its huge I want them to fit and removable dust filters (although I could just add some myself).
shanky887614
1,260
49
nice case. personally i went for antec 300 (psu at bottem so pulls heat just from graphics card
then 1 fan on top, 1 on back and 2 intake in front
the front panel has very simple clips that you press with side of case off (thumb screws to open it)
then it is removed easily)
if thats your budget would recomend antec 1200 though (3 intake fans onfront,1 on top and 2 on back)
AdrianPerry
2,859
154
Unless your putting some kind of monster build in here.....seriously don't waste so much of your budget on the case......
A cheaper mid-tower ATX case would be more than suitable and would likely leave you enough spare ££/$$ to upgrade your GPU or add an SSD/get bigger SSD.
What is the rest of the build out of interest?
Mobo?
CPU?
GPU?
PSU?
RAM?
HDD?
SSD?
hystr
15
mobo: Asus ROG Maximus IV Extreme-Z
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131760
Cpu: Intel i5 2500k I Have this already this 70 bucks cheaper($162 w/tax ,new Costa Rica batch
Gpu: Asus 6970 EAHDCII / MSI gfx560ti Hawk (I already have these too one from previous build and the other from buddy. They work fine I tested them)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121430
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127578
Psu: SeaSonic X750w gold
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151087
Ram: G.Skills Ripjaws X 8gb(2x4gb)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231468
SSD(boot drive):Intel 320 80gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167049
HDD: Samsung Spinoint F3 1tb
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Fan:CM Hyper 212+
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Display:Asus 12.5 VH226H
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236051
32inch lcd tv Symphonica
Optoma TH1020 1080P 1920x1080
http://www.newegg.com/Product/Product.aspx?Item=N82E16824219104
Already have lcd tv and projector.
AdrianPerry
2,859
154
I think this is the first build I think I've seen on TOMs where someone is actually buying an E-ATX motherboard to use with a FULL TOWER case :) Congratulations :) My vote is for the Storm Trooper between the two options.
You should MAYBE *depending how much effort is involved* consider selling the 6970 and 560Ti and grabbing a new 7970?
New 6970: $380
New 560Ti: $270
Total: $650
New 7970: $550
Similar threads
