Hey tomshardware,
I'm looking to buy a new PSU in the 750w ish range, I built my very first system almost 1 year ago (12/27/13) however I was slightly bummed because the ONLY component that wasn't new at the time was the PSU. I currently have a TX650w and its about 5 1/2 years old... and it's still going strong, zero problems from what I can tell.
Here are some PSU's that interest me, of these 3 I'm honestly leaning towards the HXi since the AX has slightly more negative reviews from users this could be since the HXi is more newer and I couldnt find major negative reviews on amazon or newegg. Also the SuperNOVA was brought up to my attention just recently, even though its not PLATINUM rated its definitely cheaper than the other 2, but $ isn't a problem here although I don't mind saving.
Suggestions, or all 3 very good PSU?
HX750i
AX760
EVGA SuperNOVA G2
My system
Z87 Asus-Pro (V-edition)
i5 4670k OC@4.5Ghz
Noctua NH-U14S
Sapphire R9 280x Vapor-X Tri-X
G.Skill Ripjaws X 8GB (2x4) 1866Mhz
1 HDD
1 SDD
6 Case Fans
HX750i
AX760
EVGA SuperNOVA G2
My system
i5 4670k OC@4.5Ghz
Noctua NH-U14S
1 HDD
1 SDD
6 Case Fans
