Need help deciding on AMD processor
dduckshooter
12
I have decided I want to go with AMD processor and I was wandering what is a good one, I have a strict budget.
I want to use it for gaming... i play games like Skyrim, CoD black ops 2, far cry 3, assasins creed 4.
Please help thanks
If he is using a dedicated GPU there is really no reason to go with a APU. He would be better off with a AM3+ motherboard/CPU instead. As said above depending on your budget you could get a FX-6300 up to a FX-8350 it all depends on how much you have to spend. Even a FX-6300 with a good GPU would make a good gaming rig.
