Need help deciding on power supply
kc517
Hello I am building my first gaming pc and I would just like advice on if the power supply I have chosen would work or if I should go with a higher wattage.
here is my pc components:
Processor: amd fx 8150
graphics card: xfx dd 7850 2gb
motherboard: gigabyte ga-970a-d3
Ram: 8gb
hdd: 2tb
Fans: 4 led case fans
Power supply: cosair builder series cx600 600 watt
Is this power supply good enough to support my other components and if not what would you suggest?
Hi - more than enough watts, maybe you might want to consider stepping up above
budget/opening price point series. Not necessary, just consider.
With Corsair that would be TX or HX series, which are more money
but usually better value.
