Need help deciding what desktop i need.
Demonsninja
14
I want to be able to run all my games on max settings "ultra" HD all that good stuff but have a very good fps, no lag. I want to be able to run the games like Tera, Crysis 3 and Archeage or Battlefield 4. What desktop would i need? I'd like to modify it down the line too. I also need a monitor that can handle all this above 25 or 26 would be nice but not too costly.
Leadbelly78
724
15
I see, at least now I do.
Just go to this pcpartpicker.com but I'm sure you know that.
Good luck.
Demonsninja
14
My budget for the computer itself is 800 Preferably below, Prebuilt or a build to do.
Leadbelly78
724
15
If you don't want to spend that much money you can go with http://www.cyberpowerpc.com/, they offer some good computers that don't cost that much $$$.
If you want to spend a lot of $$$ you can go with http://alienware.com/
It's better if you build it.
It cheaper and you can chose the perfect items.
Demonsninja
14
I want to know whats the best for my buck. 800 being the budget but less being wanted . do i want to buy something or can i make something that cost less and is better.
Leadbelly78
724
15
Good luck.
Leadbelly78
724
15
So...What should I do?
My Tower has eight or nine fan's.
The vents, the vent filters, the CPU heat vent doesn't have dust doesn't on it.
So, any other suggestion?
Should I add a better Thermal Pate?
A different case?
I bought, I built this system 4 months ago maybe 6 months ago.
Ugh, this is very annoying.
