Need help deciding what PSU I need to get
Tahnerd
11
I am upgrading my PC for a upcoming game but can't decide what PSU I should get.
When I use a calculator I get varying answers for each one:
ASUS: 750w
eXtreme: 561w
PowerSupplyCalculator: 404w
NewEgg: 721w
Computer Specs:
CPU: AMD Phenom II X4 955
Mobo: ASUS M4N68T-M-V2
GPU: AMD Radeon R9 290
RAM: 8gb (2x4gb) DDR3 1600
HDD: 930gb HDD SCSI 7200rpm
Optical: CD-ROM
I am currently using a 500w PSU with AMD Radeon HD 6450 for a GPU and I have been told that this is not enough for a 290.
Get the same one as me, works a treat AX860I, 80Plus platinum, 92% efficient, that wouldn't be stressed out by your rig either, look on Amazon, they are £145 on Amazon.co.uk if you overclock the power supply here will let the overclock be more stable also
Great PSU. Too bad it's $200 here in the states. Not worth the money when better units are available for less.
Thanks for the help so far but I was wondering something. I might be able to get a Corsair HX750 Power Supply for 85$. Do I need it and is it much better than the 60$ mail in rebate one?
http://www.corsair.com/en-us/hx-series-hx750-power-supply-750-watt-80-plus-gold-certified-modular-psu
I was planning on getting my hands on the cheapest 290 I could get, since I'm already push the amount of money I have left to spend, (I don't plan on OC.) From what I have seen, a used R9 290 should be about 190$-210$
Should I go for the 750w even if theres the chance I wont use it?
Alright. I suppose I'll go with that one then. Thanks guys!
Now to find someone to sell me a 290 D:
