NEED HELP deciding which build is better
Csmith182
19
so im buying a gaming pc of a mate, which pc would run games better (bf1, the witcher 3 etc)
CPU: i7 2600k overclockable to 4.8ghz
CPU Cooler: Cooler Master tx3 aftermarket cpu cooler.
Motherboard: ROG Maximus iv GENE-Z The highest end motherboard for this socket an absolute beast.
Ram: 8GB Kingston 1333mhz 2x4GB more can be added is an easy upgrade
PSU: Antec 750w semi modular power supply.
80+ bronze certified capable of sli or crossfire
Case: CIT G Force with 3x120mm red led fans USB 3.0 and SD card reader
HDD(Hard Drive): 2TB Western Digital Caviar Green.
GPU: Msi Geforce Gtx 105ti 4GB GDDR5
NO SSD IN THIS ONE
OR
SPECS:
Cpu: intel i5 4670 w/ stock cooler
Ram: 8gb ddr3 1600mhz corsair vengeance LPX
Case: thermaltake versa h15 micro atx
Gpu: GTX 1060
Mobo: asus h81m-k
Hdd: samsung 2tb 5400 rpm 32mb
Ssd: 32gb ssd (can speed up hdd or partition hdd)
Fans: original fan with case.
PSU: Corsair 550W VS 550
Latest posts
