Need help deciding which PSU
canhazcheeseburger0
Hello, I'm trying to decide which PSU to get. They are all in the same price range, so it makes it more difficult. The reviews for all of them are acceptable, so I'm not sure which will work out better:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817702015
Model
Brand BFG Tech
Model BFGR1200WEXPSU
Series EX-1200
Spec
Type ATX12V 2.2 / EPS12V 2.91
Maximum Power 1200W Continuous Rated at 40°C
Fans Silent 135mm Intake Fan
PFC Active
Main Connector 20+4Pin
+12V Rails 4
PCI-Express Connector 3 x 6-Pin, 3 x 6+2-Pin
SATA Power Connector 12
SLI Ready
CrossFire Ready
Modular Yes
Efficiency > 80%
Energy-Efficient 80 PLUS Certified
Output +3.3V@30A,+5V@30A,+12V1@40A,+12V2@40A,
+12V3@40A,+12V4@40A,-12V@0.5A,+5VSB@3.0A
MTBF >100,000 Hours
Approvals UL, CB, TUV, CE and FCC
Dimensions 5.9" x 3.4" x 6.5"
Features
Connectors 1 x Main connector (20+4Pin)
1 x 12V(P4)
1 x 12V(8Pin)
9 x peripheral
12 x SATA
2 x Floppy
6 x PCI-E
Manufacturer Warranty
Parts Lifetime limited
Labor Lifetime limited
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139007
Model
Brand CORSAIR
Model CMPSU-1000HX
Spec
Maximum Power 1000W
Fans 140mm Thermally Controlled
PFC Active
+12V Rails 2
PCI-Express Connector 6 x 6+2-Pin
SATA Power Connector 10
SLI Ready
CrossFire Ready
Modular Yes
Efficiency > 80%
Input Current 13A
Output +3.3V@30A, +5V30A, +12V1@40A,
+12V2@40A -12V@0.8A, +5VSB@3.5A
MTBF >100,000 Hours
Approvals UL, CE, CB, TUV, FCC, CCC
Dimensions 150mm(W) x 86mm(H) x 200mm(L)
Features
Features Supports the latest ATX12V 2.2 and EPS12V 2.91 Standards. Backwards
compatible with ATX12V 2.01
Auto switching circuitry provides universal AC input 90-264V
Over Current/Voltage/Power Protection, Under Voltage Protection and Short
Circuit Protection provide maximum component safety
Five year limited warranty with 24/7 on demand customer service
Compatible with Core i7
Parts 5 years limited
Labor 5 years limited
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341028
Model
Brand OCZ
Model OCZZ1000M
Series Z Series Gold
Spec
Type ATX12V 2.3/ EPS12V 2.91
Maximum Power 1000W
Fans 135mm double ball-bearing ultra-quiet fan
PFC Active
Main Connector 24Pin
+12V Rails Single
SLI Certified
CrossFire Ready
Modular Yes
Efficiency over 90% typical
Energy-Efficient 80 PLUS GOLD Certified
Input Voltage 100 - 240 V
Input Frequency Range 50/60 Hz
Input Current 13A
Output +3.3V@25A,+5V@25A,+12V1@83A,-12V@0.8A,+5VSB@6.0A
MTBF >100,000 Hours
Approvals UL, CUL, CE, CB, FCC Class B, TUV, CCC
Dimensions 5.9" x 3.4" x 6.3"
Features
Connectors 1 x Main connector (24 Pin)
1 x 8-Pin EPS 12V
1 x 4/8-Pin CPU
6 x PCI-E(6+2Pin)
3 x Peripheral
12 x SATA
1 x Floppy
I'm going to OC my memory, CPU, and video card, probably with 2-way SLI (Nvidia 285 or 295). Any advice would be apprciated.
