Need Help Deciding
Only 1 stick totaling 4GB of RAM? There will be a performance increase in 2x4GB modules, especially in gaming.
The AM3 build is better performance.
Will get the extra 4gb and will it be better for future proofing?
The 4GB more (totaling 8GB) of RAM or the AM3 processor? Either way both are a good choice at making your system able to handle games longer than a 7850k or just 4GB of RAM.
If you haven't already bought the power supply you could instead get a smaller unit (like 600w) and save some money there unless you plan on going CrossFire
Will be going for the AM3 then plus the 4Gb of ram
Thanks for the quick replies.
