Need help dell graphic card questions :/
G
Guest
Guest
Hi i was going to upgrade my dell dimension 3000 to a new graphics card, but i have no knowledge in that area ><. I would like to have it play games like COD 4 and half life. Please list any system specs i would need to post in order to get a valid response 😀
i was thinking about this card but again i have no idea ><http://www.newegg.com/Product/Product.aspx?Item=N82E16814130433&Tpk=14-130-433
The first thing you need to do is replace that 250 watt PSU. You can't run the graphics card you listed with that PSU at all.
Also, what resolution is your monitor?
I recommend the following PSU:
Corsair CMPSU-550VX 550W - $79.99 after rebate ($89.99 before rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
As you can see it's a very popular PSU because It's sold out at the moment. They'll have more in a few days.
The first thing the OP would need to do would be to replace the computer, the psu won't even come into play.
The D3000 does not have a PCI-E slot.
