Need help determining if Hyper Evo could fit
PCRay
4
Hello,
I am currently trying to choose a CPU fan for my Intel Core i5-2400 @ 3.10GHz. Does anyone have any recommendations on a specific fan? I am hesitant on buying the Coolermaster Hyper Evo because I don't think it might fit. Thanks all.
I can't see exactly how the fan is fit with the radiator but I'm almost certain you could swap its position on the other side ( next to the case fan) with opposite flow direction.
"Dimension: 120 x 80 x 159 mm (4.7 x 3.1 x 6.3 in)"
Take some ruler and measure it 4 cm from the center of CPU slot and heres the answer.
