I am getting a cooler master case which is right here ----->
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
With this case I am adding my motherboard which is right here
-----> http://www.newegg.com/Product/Product.aspx?Item=N82E16813131730
I am also adding a HD radeon 6950 which is right here
-----> http://www.newegg.com/Product/Product.aspx?Item=N82E16814127575 which i know in newegg doesnt list the size, but i think its a 12 inch card or something of that direction.
The power supply is right here which will be added in the case
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044
I am adding a cooler master hyper 212 plus cpu cooler in there also. I was doing the measurements it looks like it will fit just right, but I need to make sure. Could you guys help me out
and my selected PSU will work fine right, its 650W... and I think it has all the connections it needs.
