https://ibb.co/cCnKxe
https://ibb.co/ecRCHe
https://ibb.co/kpM1Az
Hey all I just purchased a Gigabyte gtx 1060 3gb GV-N1060IXOC-3GD Graphics card that is in need of repair. Included are images of the card and the solder points on the board missing capacitors. I need figure out which surface mount capacitors I need to buy in order to replace the ones that broke off the LB502 and C903 solder points. The guy I purchased the card from said the card slammed onto a table or something and these resistors popped off. He sent it for an RMA and they couldn't repair it for him put did determine that it was these were the missing capacitors that needed to be replaced. I also I'm not sure if the solder pads are still there and how I should go about the repair. I do have soldering iron/hot-air station. Its not the highest quality tool but its still pretty much new. Any advice and insight you all have would be greatly appreciated.
