The sound has been happening and getting increasingly worse since the big west coast heat wave in the summer of 2021. I feel like I can't describe what kind of sound it is accurately. I've tried sampling dozens and dozens of computer sounds from youtube over the months, especially the last 24 hours and not one of them sounded like this.
It's like an up/down roller coaster sound pattern that goeswhew whew like a very quiet extremely low pitch police siren. It revs up during activity like opening other windows or applications and is noticeably (but not necessarily 'significantly') louder and more common while gaming. It pulsates the sound where if it were repeating every second, the audible part of the noise loop is about 0.4-0.5s. The speed of the sound can pulse up quite quickly, to 2-4 times per second and go as slow as once every couple of seconds per loop.
I do believe I have tried gently stopping each fan in the tower and listening for it to stop with about a 90% certainty (if not more) that it's not a fan producing the noise, though I did not test the PSU fan. I've disabled all the C states and intel speed shift technology in the bios. Running a bit of a torture test on prime95 doesn't seems to have any drastic significance in the sound, just audible full RPM fans as one would expect.
It's beginning to drive me completely mental here and if I can't figure out the cause and get the problem fixed or replaced, I may be looking at getting an entire new system which I just really can't afford to do right now.
I have recorded a fairly low quality sound clip from just behind the tower in front of the I/O ports by the fan to try and pick up the sound. It's my only means of recording sound and it's not very easy to separate from the other sounds in the clip but you'll hear static, some clicking noise (that I don't hear with my ears, only through this clip), a fan blowing noise in the latter part of the clip but constantly throughout you should also hear the whew-ing noise pulsating amongst everything. I'm fairly certain the sound is coming from the CPU region of the tower layout.
Here is the sound clip. Apologies for the quality.
Specs:
-Intel Core i9-9900K @ 3.60Ghz (not overclocked as far as I know)
-Gigabyte Z390 AORUS Pro Wifi-CF (Motherboard)
-nVidia GeForce GTX 1080 Ti (11GB VRAM)
-2x 16 GB Dual Kit RAM (Corsair Vengeance - Low Profile)
-650W SeaSonic Focus 80+ Gold Certified PSU
Please, someone, anyone, help me figure out where this is coming from! I'm desperate here
Specs:
