I just got new parts in for a build today. After putting everything together, my motherboard is showing POST error lights for BOOT and VGA. However, my GPU was working just fine earlier today before I rebuilt things.
The specifics:
The build I came from:
I5 4690k
Gigabyte GA-Z97X-UD3H-CF motherboard
16GB G.SKILL RipjawsX DDR3 1600
RTX 2070 Super
Seasonic 520 Bronze
The new build:
Ryzen 7 3700X
ASRock X570 Extreme4 motherboard
16GB G.Skill Trident Z Neo 3600
RTX 2070 Super
Seasonic 520 Bronze
I know the PSU is bronze and should be upgraded etc etc, but it shouldn't prevent me from booting up with the current components AFAIK. The system POSTs fine with just CPU, CPU + 1 stick RAM, CPU + 2 sticks RAM, and everything without the 2070. When I install my 2070, the Boot and VGA LEDs on the board stay lit. I put in my old R9 390 and everything is up and running... Currently using it to type this post. I always take care to be extremely gentle with components when they're out, and obviously the PCI slot is working (the board only has one, so I can't try another one if I wanted, and it's working on this card.)
I've taken out the CMOS battery to reset that, I've reseated the GPU a few times, reinstalled everything except the CPU and cooler...
Soo... Is there anything else I need to check? Did my card somehow mysteriously die between this morning and this build, despite taking the precautions I usually do (after all, my previous card that I upgraded from and stored away for the last few weeks is still working)?
The specifics:
I5 4690k
RTX 2070 Super
Seasonic 520 Bronze
The new build:
Ryzen 7 3700X
RTX 2070 Super
Seasonic 520 Bronze
